KM5035 with black copies now a pattern
  • copyaction
    • Oct 2007
    • 985
    cleaned contacts and replaced interlock switch pack on left rear of machine, now getting a "texture" pattern in background.
    so far replaced drum, main charge, developer unit, transfer roller unit and interlock switches.
    only using oem supplies
    should be able to see pattern on this sample
    anyone seen laser do this?
  • Kyo fan
    • Dec 2013
    • 368
    Re: KM5035 with black copies now a pattern
    At first it looks like main charging, and than developer unit. You've done all of those. You could clean the laser unit, though it doesn't look like it. Which contacts exactly you've cleaned in the first place?
    • Geo
      • 662
      That pattern is a classic charger grid pattern. Are you using a new charger assy? Did you try a different charger ? Did you clean/check ALL the contacts on the machine side for the drum and charger assy? Also it's possible the spacers on the charger are the wrong size ( check the roller colors)
      Good luck..
      • copyaction
        • Oct 2007
        • 985
        Yes I ordered the whole maintenance kit, brand new charger and drum
        • daveh12
          • Jul 2012
          • 157
          Good luck..
          Agree with this. When you see that grid pattern it's almost always charger related. Check to see if one of the spacers on the charger didn't fall off when you inserting it, this can happen easily.
          • copyaction
            • Oct 2007
            • 985
            Tried another new drum and main charge. Solid black copies. I'm out!
            • Geo
              • 662
              Silly question ...did you order the correct MK and or Drum....I remember 5035 is different from 3035 and I don't remember if using the wrong drum will code.....BUT if the images are black your looking at a charge issue/ charger. You seem to be on the right tract given that changing the DM assy produced a change...not what you wanted , but a change. BTW...Never had one with your posted example that was not fixed by a new charger or drum/charger combo.
              Good luck..
                • 22999
                Good luck..
                I can't remember what symptom, but it will not copy with the wrong drum. You get an error message. =^..^=
                • logrady2331
                  • Feb 2011
                  • 301
                  Looks to me like the MC grid is contacting the drum. I've seen them sag right out of the box. Try taking the MC out and check the tension one the grid. It wouldn't be the first time I've seen multiple production lots with the same problem.
                  • JR2ALTA
                    • Feb 2010
                    • 2031
                    Try the high voltage board.
                    • copyaction
                      • Oct 2007
                      • 985
                      The drum I got is 302FG93016
                      and I too have fixed many of these over the years with a new main charge corona.
                      the thing that really concerns me is it alternates between very dark with a visible image underneath and a solid black page.
                      • daveh12
                        • Jul 2012
                        • 157
                        I think the code you get is C7410 if you use the wrong drum.
                        • daveh12
                          • Jul 2012
                          • 157
                          If you are getting solid black pages now, that is the same as if the machine had no charger in it at all. So if it isn't the charge it has to be the contacts to it.
