TA-6052ci(generally series TA-xx52ci) - color print tone
  • lebo
    • Aug 2012
    • 88
    [Misc] TA-6052ci(generally series TA-xx52ci) - color print tone
    Hello friends. I have great problem, I need to resolve color print tone drift on new TA-6052ci and new TA2552ci. I tried several settings PCL, KPDL, GDI compatible and another settings in driver, but without any pos. result.
    In the concrete the blue tones are printed pale-blue (green-blue).
    Let to see attached files. Original printed PDF and scanned print output from the machine. Scan of print output is not precise, real print output is a bit darker.
    Great-great thanks to you all for your ideas and advices.
    scanOfprint.PDF
  • lebo
    • Aug 2012
    • 88
    Re: TA-6052ci(generally series TA-xx52ci) - color print tone
    Here is the output print.
    • Kyo fan
      • Dec 2013
      • 368
      You will need to play with color tables (U485) to get close to what you want. When dealing with blue tones, the most success I've had was with Ricoh (RH) color table.
      • lebo
        • Aug 2012
        • 88
        Thank you for your advice, I will try it on Tuesday next week (due to Easter day)
          • 23008
          Have you done a color calibration?
          Clearly cyan and magenta are problematic. =^..^=
          • lebo
            • Aug 2012
            • 88
            [ATTACH=CONFIG]36360[/ATTACH]
            What calibration do you mean ?
            Machine is new and during installation I made registration (auto + manual) > calibration > again registration > U410
              • 23008
              There's a little more to it than that. You should take a glance at your manual. =^..^=
              • lebo
                • Aug 2012
                • 88
                Thank you for your advice. The setting Ricoh color table move blue tones satisfactorily, even it also move gray tones a bit to gray-blue.
                But costumer takes stand on his blue.
                Thank you again.
                • jmaister
                  certified scrub
                  • Aug 2010
                  • 755
                  if you are referring to how the solid colour isn't solid. There's no way around it. Kyocera developer does that since Taskalfa ###0ci. Also note that mfps uses CMYK so the maximum colour it can simulate isn't in the millions, only hundred thousands. What that translate to is whatever is on the Monitor more often than not doesn't match whats on the paper.
                  You could shift the colour table in print driver manually but it shifts the entire colour spectrum, cant just change one hue alone.
                  Idling colour developers are not healthy developers.
