CS-255 black copies
  • campy
    • May 2012
    • 315
    CS-255 black copies
    I have a CS-255 with totally black copies. The maint report prints out fine. Is it the scan assly or board? The lamp is on when scanning.
  • Tonerkiller
    • Oct 2012
    • 668
    Re: CS-255 black copies
    Replace the eng board
    • campy
      • May 2012
      • 315
      Not to doubt you, but can it be anything else before I order a repaired one from Hytec? Are these boards common failures? I have 3 of this model in the field and this is the second one with a bad engine board.
        • 23008
        Are there voids on your totally black copies? How about U089 Sample Set?
        • Santander
          • May 2009
          • 768
          If the maintenance report prints out fine, then it is not a print engine problem but a scanning issue. Just because the lamp is on does not mean that the scanning for copying is working properly. You failed to mention if the black copies occur from both the document processor and the glass? How about scanning a page to a network folder or to a usb drive? Is it still all black?
          • campy
            • May 2012
            • 315
            It is from both the glass and DF.
            • Geo
              • 662
              Know problem with this box . I attached the T.B.
              • JVergin
                Service Tech / IT Rep
                • 216
                Yep, we've had this with just about every one of them out in the field - low and high volume.
                • sparkycivic
                  • Apr 2017
                  • 348
                  Try an EEPROM on the main bd...
                  that worked for me once, black copies yet fine prints.
                  • campy
                    • May 2012
                    • 315
                    It was the main brd. I ended up buying a used CS-305 for less money than having the board repaired. Thanks everyone.
