TA8001i no trays 3 & 4
  • ntbann
    • Jan 2012
    • 628
    Hi all. I have a TA 8001i that does not recognize trays 3 & 4. Talked to tech support and they say paper feed pwb 2. Just wondering if anyone else has run into this? Thanks in advance!
  • Geo
    • 662
    Re: TA8001i no trays 3 & 4
    Did you try the standards...U906 , full firmware flash and cleaning reseating the DIMM.
    Good Luck
    • habik
      • 2013
      As GEO plus Check the rear of cassettes as there might be paper scrunched up not allowing lift or blocking sensors continuously throwing the T3/4 offline.
      Sent from my iDon't believe in marketing device using Tapatalk
      Firmwares HERE
      • ntbann
        • Jan 2012
        • 628
        Firmware updated, no paper behind cassette, and reseated connectors. The machine does not recognize that the LCC is installed. Just trays 1 & 2 show up in tray settings.
        • 20gaugeO/U
          • 557
          Had a booklet folder disappear from a finisher before after a few hundred thousand prints. Not only reseated connectors but cut all the tie wraps in there and put select ones back in much more loosely... ran a couple million more now without disappearing again... knock on wood. Just a thought
            • 23009
            I have not seen a bad feed PWB 2. But I have seen a bad feed PWB. Tray #1 fed fine, but misfeeds (J1302, 1303, 1304) from trays #2, #3, & #4 every time. Feed PWB does not send the ground signal to energize vertical feed clutch PCCL. I tested the clutch signal V_Feed_CL in U032 > Feed. Pin connections YC5 pin2 (24vdc steady), YC5 pin3 (ground switching) on the Feed PWB.
            It is not inconceivable to have a blow feed PWB2. =^..^=
            • Santander
              • May 2009
              • 768
              Just because there is no paper behind the drawers now does not mean that there was not before and left some paper shards in the connector. Have seen this before where the user opens and closes the drawer several times before realizing that there is a sheet of paper behind it. By that time there is a paper shard stuck in the connector causing the unit to not recognize the drawer. I would take a close look at the connector at the back of the unit to make sure there is no paper stuck in it.
              • ntbann
                • Jan 2012
                • 628
                FYI the paper transport clutch took out my lcc paper feed pwb.
                  • 23009
                  Thanks for posting back. Those clutches should be listed s consumables, since they rust out so quickly. At least they're all the same part number. =^..^=
