system error F000
  • Reeves
    • Apr 2012
    • 296
    [Error Code] system error F000
    i have a kyocera 4501i at first it had a white screen after replacing the screen it is displaying system error F000 what could be the problem?
    • 23009
    Re: system error F000
    Dis you re-load the firmware?
    On kyocera machines the firmware for each board resides right there on that board. So let's say you you remove an operation panel with version 2.0 firmware, then install an operation panel with version 3.0 firmware. You've got a firmware level conflict. Just re-loading the firmware any time you change a board is a good policy.
    And please don't ask me for the firmware. =^..^=
    • Reeves
      • Apr 2012
      • 296
      i have tried to reload firmware but its not responding its just displaying system error
