TASKalfa 3051ci error C2840
  • kyove
    • Apr 2015
    • 62
    Hi Guys,
    I have a problem with a TASKalfa 3051ci. Initally sometimes, now often give error C2840.
    I have already clean the transfer belt cleaning section and the waste toner cleaning pipe.
    I manually rotate transfer belt cleaning motor and I did not notice a unusually load. Turning is soft!
    What can I do? Any ideas?
    Thank you in advance,
    Kyove
  • AlbertK
    • Jul 2014
    • 90
    Re: TASKalfa 3051ci error C2840
    I had the same problem on a higher volume machine and found a bulletin regarding the change of the TR cleaning section for models before a certain serial number.
    Had to do Firmware and change TR unit.
    Is the rest of the waste path clean? does the waste reach the waste box?
    I would do Firmware first and then test before changing the TR unit.
    The product may be brilliant and the salesperson proficient, but if the technician isn’t efficient, then the story will end there.
    • kyove
      • Apr 2015
      • 62
      I'm already on the latest firmware:
      TASKalfa 3051ci, 3551ci, 4551ci, 5551ci
      Version: 06.04.0020 (2016-12-05)
      Release Date: 2016-12-12
      The waste path seems to be ok. WT cleaning pipe has normal dirty inside, even the transfer belt cleaning.
      I carefully vacuum the inner unit (or image formation holder) and dirty seems to be on the average.
      Machine has 213k copies: 84 bw and 129k color.
      Any suggestion?
      Can you send me the bullettin please? My email is blackjf@libero.it
      Thx,
      Kyove
      • darry1322
        • Oct 2010
        • 817
        Change the transfer belt.
        • kaborwen
          • Feb 2010
          • 146
          Hi,
          I have the same problem. Can you give me the SB please ?
          Thanks you.
          • craigster
            • Apr 2016
            • 201
            latest firm for that model is 7.01
              • 23010
              Make sure that the 32pin connector is entirely seated ... no bent pins. =^..^=
