Hi all,I did a mistake when ordering a DP for TASKalfa 4550ci. I order DP-772 instead of DP-771 or DP-770. So I can't install it. Somone get solution to intall DP-772 on TASKalfa 4550ci? Please need help.
DP-772 to install on TASKalfa 4550ci
Re: DP-772 to install on TASKalfa 4550ci
The only solution is to order a compatible DP. And yes, the DP-771 and DP-770 are compatible choices. =^..^=If you'd like a serious answer to your request:
