We just got this wonderful POS off of the wholesale truck, and among other things it is giving a steadily intermediate J0533. I do not see it multi feeding but it is creasing the lead edge starting approx 36 mm and ends at approx at the 132 mm mark. Generally it stops at the 303NF9401 PARTS MIDDLE ROLLER UNIT SP...between the PF and machine. Although sometimes it will continue to feed and cause other jams but the crease it always consistent.
I have replaced or swapped the following:
Deck 3 tires
Deck 3 Feed unit
PF 740 right door
5500 right door
303NF94070 3NF94070 PARTS ROLLER CONVEYING VF SP
Deck 3 LCT
Deck 3 lifter motor
PF 740 drive section
Between this and a customer machine, I am at my wits end and could use a fresh line of thinking.
Deck 3 tires
Deck 3 Feed unit
PF 740 right door
5500 right door
Deck 3 LCT
Deck 3 lifter motor
