ta 3051ci noise
  • delsignore2410@rogers.com
    • Nov 2015
    • 5
    [Misc] ta 3051ci noise
    I have an issue with a ta 3051ci Kyocera mfp. Only first print in the morning there is a strange sound that seems like the exit assy area, then goes away for the entire day ??
    • 23010
    Re: ta 3051ci noise
    Are you sure it's not before and after each print job? That's much more common (and I know how to fix that). =^..^=
      • Nov 2015
      • 5
      Re: ta 3051ci noise
      Thanks for your reply, it was the fuser assy..
