M3540IDN FIRMWARE AND PAPERcut PROBLEM
  • n25an
    • Jul 2008
    • 1030
    Is there any gotchas that I need to be aware of when installing firmware on a machine with papercut embedded...
    My fear is that I install the firmware and demolish the machine...
    I am installing firmware because this machine will not hold any addresses in the addressbook after its rebooted...
    I am going to check with kyocera to see what firmware to use...
    there are other issues with the machine and papercut...
    1. it prints to separation pages but I believe that is an issue with the separation page needing to be edited... its a windows 8 windows server issue...
    2. some time papercut authentication does not recognize the login right away... I believe the firmware should fix that but if it does not then its something papercut is working on...
    any help you can send will be much appreciated...
    Sad To Say I Don't Have a Life
    I do this stuff on the weekends too
  • wragsdale
    • Jul 2014
    • 188
    Re: M3540IDN FIRMWARE AND PAPERcut PROBLEM
    I ran into this on an M3540 without PaperCut. I realized that the non-optional fax PWB had been removed by a previous tech to solve a fax related C code (lazy). Once I had a replacement, I had to flash firmware and run U021 and the address book returned to normal function.
    Sorry, I can't be of much help regarding PaperCut.
    • tmaged
      Owner/Service Manager
      • Oct 2008
      • 1868
      I've never had a problem with it on other models.
      Hope that helps !
      -Tony
      www.dtios.com
      Become a fan on Facebook
      • Ctl-Alt-Del
        • Jul 2006
        • 430
        We have a few accounts that use Kyocera MFP's with PaperCut and I've never heard of any problems caused by firmware upgrades and we're pretty consistent about keeping firmware updated.
        • n25an
          • Jul 2008
          • 1030
          you just answered your own question...
          • n25an
            • Jul 2008
            • 1030
            installing the latest firmware on the machine... it did not crash papercut...
            then we edited the separator page file..
            http://www.copytechnet.com/forums/co...tml?highlight=
