m2535dn stopped scanning to gmail
  • Copystar Tech
    • Sep 2010
    • 59
    I have a customer that had scanning to email through a gmail account suddenly stop working. Tech support remoted in and said is was a networking issue. Customer was convinced that it was our machine. To prove it, I brought his old machine, which was scanning perfectly when it was replaced, and it failed also. This created a conversation with his ISP which lasted 3 hours to determine the wireless router was bad/conflicting/incompatible. Replaced the router today but still won't scan. I've tried SSL/TLS over port 465 (which is how it always worked in the past), receives a error 4803. STATTLS through port 587 which gives a 2201. A whole slew of different combinations of port 25, 2525, 8025, 923. I cannot get this thing to go through. Gmail server is smtp.gmail.com and the account has 2 step verification off and allow less secure apps on. I've been working on this for 2 days and all resources come to a dead end. Any ideas, or maybe a work around at this point to solve this issue? (Scanning to smb or usb is not an option, customer is used to a one button scan and forget about it)
    Re: m2535dn stopped scanning to gmail
    doesn't google use port 8080?
    • Copystar Tech
      • Sep 2010
      • 59
      I was basing ports on this article:
      Set up a device or app to send email through Google Workspace Who this article is for This article is for Google Workspace administrators who want to send email from devices or apps in their
      • guitar9199
        • Sep 2016
        • 1100
        Gmail's Default SMTP Settings
        Gmail SMTP server address: smtp.gmail.com
        Gmail SMTP username: Your Gmail address (e.g. example@gmail.com)
        Gmail SMTP password: Your Gmail password
        Gmail SMTP port (TLS): 587
        Gmail SMTP port (SSL): 465
        Gmail SMTP TLS/SSL required: yes
        You might also look into the DNS settings on the copier. I've had issues in the past that changing the DNS to Google's settings..
        (8.8.8.8 Primary- 8.8.4.4 Secondary) has helped.
        ...good luck.
        • sparkycivic
          • Apr 2017
          • 348
          On some machines, for reasons I don't understand, it's necessary to login to the Google account using a computer, and alter the POP mail settings so that Google will allow remote access to the account from "less secure apps" as per https://productforums.google.com/for...8/_YOot9HvAwAJ
            • 23009
            Is the Gmail account active?
            Certain of my customers do not ever access the gmail account. Between 90 and 100 days of inactivity the account goes inactive. When you try to log on, they put you through a text/cellphone security procedure to re-activate the account.
            You would think that after three times in a year these customers could learn how to log onto Gmail and delete off the junk emails. That's all that you have to do to keep the free account active.
            Naturally, they ask me what their login and password are. =^..^=
            • Copystar Tech
              • Sep 2010
              • 59
              He wants to use his everyday email account so definitely active. I also have used my own, which works perfectly fine from within my office on a similar machine. Doesn't seem to be the gmail account. Limits it to the router, or ISP. Can a router be blocking my SSL?
              • sparks45
                • Jun 2014
                • 25
                Try aspmx.l.google.com for smtp server and port 25 with any sending address. should work with DNS entry as googles
                • wragsdale
                  • Jul 2014
                  • 188
                  Have you tried your GMail account on-site? or a different smtp server on-site? Keep isolating.
                  • JR2ALTA
                    • Feb 2010
                    • 2033
                    try gmail ip address instead of hostname 173.194.74.100
                    • kyofox
                      • Mar 2015
                      • 5
                      Try to log in to your gmail account on-site. Maybe you have a double security setup for entering the account. For example, if gmail is sending a code to a mobile phone to enter the account. In that case, you will not be able to scan through the account that is set.
                      Sent from my SM-G935F using Tapatalk
                      • NeoMatrix
                        Senior Tech.
                        • 3513
                        If the rest of the MFD communications work okay.
                        You might like to test for out of date security certificate on the MFD?
                        Dump the certificate and reinstall with a new one.
                        Being Wi-Fi comms check that no one else is using roaming devices with a fixed/alloc IP address which might be getting a conflict IP with the MFD. Ie phone laptop...
                        Such be the case move the fixed IP address of the MFD up out of range of any DHCP
                        allocation.
                        What is the comms speed of the network. I'm thinking in terms of device handshake and throttle back or retries before dropping out.
                        • Brianneoe
                          • May 2015
                          • 322
                          PING smtp.gmail.com (173.194.175.109)
                          44 bytes from 173.194.175.109 : icmp_seq=0 ttl=48 time=42 ms
                          44 bytes from 173.194.175.109 : icmp_seq=1 ttl=48 time=23 ms
                          --- smtp.gmail.com ping statistics ---
                          2 packets transmitted, 2 packets received, lost 0.0 %
                          • JR2ALTA
                            • Feb 2010
                            • 2033
                            Yea....I'm thinking Gmail may have more than one server. but thanks.
                            • Brianneoe
                              • May 2015
                              • 322
                              My bad
