T/A 8001i OCR data error
  • logrady2331
    • Feb 2011
    • 301
    Hello all again! I have the same 8001i I just asked about the web interface. I updated the firmware and the first time I did it I got a CTRL error. I downloaded the firmware again, re-flashed it and it recovered and finished the firmware upgrade. Now when I power it up it goes to ready then throws "OCR dictionary data not properly installed". I can clear it and it doesn't come back until the power is cycled. I saw a zipped folder in the firmware package titled "OCR" something. Not sure if I did the upgrade properly but I'm used to just sending all the firmware to the root of the usb stick and just plug it in and let it do it's thing. Any suggestions would be greatly appreciated.
    • 22999
    Re: T/A 8001i OCR data error
    Firmware has not changed in it's installation.
    A common mistake is to extract the firmware that is downloaded, then discover that there are compressed files in the extracted folder, then extract those files again. You only need to extract once. The MFP will deal with the remaining files that are compressed.
    How big is your USB? Use the smallest possible.
    Are you using Turbo?
    Are there other files/versions on the stick?
    I haven't had a Kyocera firmware failure in a good long time. =^..^=
    • logrady2331
      • Feb 2011
      • 301
      The stick is a new Sandisk 4 meg, used turbo the first time, re-flashed with non turbo, no other versions on the stick. I started with a freshly formatted (fat 32) stick. I haven't tried to re-flash the third time. I'll do that Monday. My guess is that will fix it.
        • 22999
        One last thing:
        I don't know how much it matters, but I'll usually disconnect the network and fax cables during firmware downloads (and during most service, since most endusers will continue to send print jobs while you're attempting to service their machine). =^..^=
        • logrady2331
          • Feb 2011
          • 301
          Thanks blackcat. Good point on the network cable. I'll re-flash on Monday and let you know if that fixed it.
          • logrady2331
            • Feb 2011
            • 301
            Blackcat, I re-flashed the firmware using a different USB stick and it worked like a champ. Thanks for the input.
              • 22999
              I'm glad it worked. =^..^=
              • iraqi tech
                • 20
                Hi
                Can I have a copy of the firmware please, I have a machine that shows ''PLEASE WAIT'' , and a friend of mine suggested to do a firmware .
                Thanks in advance.
                • ss12
                  • 289
                  Another tip is to remove the ES.Skip file,this will ignore any existing firmware that is on the same level on the mfp and rewrite everything
