ta 6501i jamming
  • n25an
    • Jul 2008
    • 1030
    ta 6501i jamming
    I got a 6501i... customer complained its jammming...
    I went in found rollers from tray 1 and 2 and high capacity tray worn down...
    replaced them... got one jam... took all the paperfeed sections out and reseated... ran like a champ...
    Customer called back... machine is jamming... cam back ran 400 pages on each tray... nothing... tray 1, tray 2 and high capacity...
    jam codes are 511, 512, 533
    message for codes multiple sheets fed in tray 1, 2, 3
    error means feed sensor does not turn off during paper feed...
    I have done rollers... firmware... and visual inspection... nothing blocking the path...
    I am thinking its the paperfeed clutches or a solenoid if there is one there...
    checking if I am barking up the wrong tree or if there is another direction that I need to think of...
    Sad To Say I Don't Have a Life
    I do this stuff on the weekends too
    • 23008
    Re: ta 6501i jamming
    Clutches. They will all look about the same: spilling rust dust everywhere
    (8) 302KV44041
    4 for lower desks #3/4
    4 for trays #1/2
    • n25an
      • Jul 2008
      • 1030
      sounds like you are talking about the clutches in the paper drive units
      parts drive unit paperdeck 303NF94040
      parts feed drive unit h 302N493030
      also would you mess with the one way clutches on the paperfeed rollers,,,???
      (8) 302KV44041
      4 for trays #1/2
        • 23008
        parts feed drive unit h 302N493030 ...
        Yes.
        ... also would you mess with the one way clutches on the paper feed rollers,,,???
        Probably not. I can't say that I've seen one of those Kyocera one-ways fail.
        Only if the clutches didn't do it.
        • n25an
          • Jul 2008
          • 1030
          thanks so much... just one more question... if I can beg your indulgence... in the service manual where it says you will see the stain when it fails what does that mean... is that referring to rust...???
          Yes.
            • 23008
            I haven't seen that particular notation, but yes that's plausible. =^..^=
            • n25an
              • Jul 2008
              • 1030
              I updated the firmware again... and ordered the parts... hopefully that will fix it... thanks again...
              • n25an
                • Jul 2008
                • 1030
                there are 9 clutches... 8 in the gearboxes... and 1 outside... that was fun... not...
                • Scottb
                  • Apr 2013
                  • 306
                  It gets better after doing 10 or 15
                  • Kidaver
                    Ghoulscout
                    • Apr 2011
                    • 912
                    There is a black cover guide you have to remove on the paper feed units when replacing the feed rollers....lazy techs will not screw these back in or even put them back in and you will get jams and skewing all day long
                    "In a cruel and evil world, being cynical can allow you to get some entertainment out of it."
                    • n25an
                      • Jul 2008
                      • 1030
                      looks like it worked... thanks...
                      (8) 302KV44041
                      4 for trays #1/2
                        • 23008
                        Cool! =^..^=
