On the left lower door, the latch hook "stub" holding the latch hook on one side of the Vertical paper path assembly broke. It looks to me that you have to change the whole paper path assembly to fix it. Is the any other way to fix this without buying the whole assembly ? I am not even sure where I can get one.. Any help is so appreciated. Thanks so much !!
TA 300I Lower left door paper latch broke. Door doesn't close causing jams
Re: TA 300I Lower left door paper latch broke. Door doesn't close causing jams
If it were me, I would dig through my cornucopia of shoulder screws and find a couple various 6mm diameter board spacers, inside threaded to 3mm or 4mm. I would remove whatever components were in the way, then insert a 3mm or 4mm screw from the outside of the frame, then a flat washer, then the frame, then the board spacer on the inside. I would put a drop or two of Loctite or cyanoacetate on the screw threads to keep it secure, then quickly snug it up.
That's all assuming that the post is ~6mm and there remains a hole in the frame. What do you think?
=^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^= -
=^..^=Comment
