Kyocera 5050 Error (C7900)
  • kataria2013
    • Jul 2025
    [Error Code] Kyocera 5050 Error (C7900)
    Km 5050 displays C7900. I have changed everything like new drum unit, new boards (engine and main) , checked the wiring section but still the problem is not solved. Im fed up of this problem if someone knows plz help
    Sent from my ONEPLUS A3003 using Tapatalk
    Re: Kyocera 5050 Error (C7900)
    what does the manual say is the issue?
    • kataria2013
      C7900 Drum unit EEPROM error Reading from or writing to EEPROM cannot be performed.Remarks : Check the connection of connector on the engine PWB and the continuity across the connector terminals. Repair or replace if if necessary. Replace the drum unit. Causes :
        Km 5050 displays C7900. Im fed up of this problem if someone knows plz help
        welcome to the tech world.
        • kataria2013
          Sir is there any solution to this?
            • 23008
            Have you changed the drum unit? That's the only cause I've ever seen. If that didn't do it, then the engine PWB. =^..^=
            • Geo
              • 662
              You may be using the wrong drum unit. If memory servers me correctly the 4050/5050 takes a DK 716. The 3050 takes a ( DK 715) and it will fit but throw a code . This was a common mistake.
              Good luck.
