Taskalfa 300i black lines
  • ricmartinho
    • 142
    Hi there!
    I have this taksalfa 300i that's printing with black lines. I want to do Drum Refresh but this machine has MyQ and I can't enter Management Mode.
    I'am able to enter Maintenance Mode but there is no option to do Drum Refresh.
    Can anyone help?
  • Tonerkiller
    • Oct 2012
    • 668
    Re: Taskalfa 300i black lines
    The drum refresh will not solve the issue. Print a counter page. Is the line there? Can you see any ware on the fuser?
    • ricmartinho
      • 142
      • The_Murph
        • 96
        Are they fine, consistent width? Are they edge to edge or is there a blank edge on either side? If all answers are yes, you likely need a drum.
        If you phrase your inquiry properly, you will get the answers you seek...
        Good Luck ... You'll need it! HAHAHA!
        ~Big Dan~
          • 23010
          Samples? =^..^=
          • Has Been
            • Nov 2012
            • 48
            Originally posted by ricmartinho
            Hi there!
            Can anyone help?
            Try sanding down the mag roller with Scotch Brite
