6550ci skews on 2nd side
  • beaker020
    • Mar 2006
    • 63
    I have a customer with a TA 6550ci with 900k on it and it just started skewing on the second side of 2 sided copies and prints. It skews on all sizes but is most noticeable on ltr-r , the customer doesn't use legal. I have cleaned all the duplex rollers, tried adjusting the duplex motor speed and no difference. The fuser was replaced about 3 months ago.
    Any ideas?
    Lance
    • 23008
    Re: 6550ci skews on 2nd side
    Is the DP skewing or the copy paper? Test 1-2 duplex. That will help you differentiate. =^..^=
    • beaker020
      • Mar 2006
      • 63
      Yes, I am copying 1-2 duplex. Plus it happens on Prints from the computer as well as copies
        • 23008
        Check that there is pressure from the white idler rollers at each location through the duplexer. =^..^=
