Alphard series wrinkling envolopes through the bypass
  • copiertec
    • Jan 2016
    • 2211
    I have a TA 3500i wrinkling envelopes through the bypass. Firmware is current 12.01, updated new-style fuser, I have tried various paper type settings and have tried adjusting temps.
    Has anybody had this issue with this series and were there things you have changed to resolve or alleviate the issue? I know in the II series the fuser is different design and I have not had any wrinkling issues on these boxes once set to envelope. Any help would be appreciated.
    Thank you in advance,
    Copiertec
  • Santander
    • May 2009
    • 768
    Re: Alphard series wrinkling envolopes through the bypass
    Copiertec
    Has your customer recently changed the manufacturer of the envelopes they use? We have had a number of cases where a customer has printed envelopes for months on this model with no problems and then purchased [typically] cheaper envelopes and started to have this problem. Wrinkling of the envelopes is more a function of the envelope itself not being folded properly, if the folds are not square wrinkling will occur as the envelope passes through the fuser and because it is not folded square create a ripple on the surface which results in the wrinkle. It is not always the machines problem!
      • 23010
      It's usually more about the envelopes than about the MFP.
      Are the envelopes inflated with air? Best results without air, pressed flat.
      Do they have triangular, trapezoidal, or square flaps? I prefer trapezoidal or square flaps.
      Is the flap open or closed? Preferably open flap.
      How many envelopes are you loading at a time? On a MFP, 25 or less.
      What media type setting? Thick1 or the equivalent.
      Can you dedicate the bypass tray exclusively to envelopes and adjust separation accordingly?
      I usually recommend that my customers buy several different brands and types of envelopes from their regular office supply and see which has the least problems. =^..^=
      • CWP
        • Jun 2013
        • 168
        copiertec, my understanding is that you can use the 3501i series fuser (which has the pressure release mechanism) in the 3500i and when the media type is set to envelope it will reduce the pressure and the wrinkling.
        • copiertec
          • Jan 2016
          • 2211
          Thank you for the input, Santander. We just put this box on site about 3 weeks ago, (it was part of a multi- package deal the sales-drones put together) and of course the customer, swears there "old copier did not wrinkle the envelopes." Of course the envelopes are pre printed with their logo which I believe increases the probability of wrinkles occurring. I will try different envelopes, making sure both (original and new envelopes) are flat. I just seen also posted to try the 3501 fuser as well.
          • copiertec
            • Jan 2016
            • 2211
            I agree, Blackcat. I've always hated envelopes and fusers, it's a gamble sometimes. They are the triangular type, but are pre printed with the customers logo and return address. It's basically just one or two envelopes here and there throughout the day that are feed from the bypass. I tried these paper settings so far... envelope, thick, glossy, transparency, etc. I even tried adjusting fuser temp as low as 135, to as high as 190, no dice. Ive never had good luck with pre-printed envelopes, they are the worst in my opinion. Also, they are running labels through the bypass, so I can't dedicate it to envelopes. I just seen a suggestion to try a II series fuser (3501) to see if that works... I'm going to give it a whirl.
            • copiertec
              • Jan 2016
              • 2211
              Thank you... I will give it a shot and let you know. I think there is a motor in the II series boxes that engage that release mechanism on the fuser, but it's worth a shot.
              • Geo
                • 662
                This may sound strange , but I usually find that cheep envelopes work best because they they tend to be thinner than better quality ones.
                Good luck..
                • Tonerkiller
                  • Oct 2012
                  • 668
                  I have been down this road, the only solution is different envelops.
                  • Ctl-Alt-Del
                    • Jul 2006
                    • 430
                    If they run more that 20 envelopes a month I would recommend buying your customer a $179 HP LaserJet to run their envelopes on and be done with the issue. I have been working on Mita/Kyocera gear since they had three digits and they suck for envelopes, what might work today will almost always cause a problem tomorrow. The $179 is cheaper than the labor cost of two service calls and if they run a lot of envelopes you will get more than two service calls. ADDED BONUS: there's a huge margin in aftermarket HP Toner.
                    Just my $0.02, have a nice day
                    • copiertec
                      • Jan 2016
                      • 2211
                      I was able to take some envelopes and try them in another machine, I ran them through a Alphard II series. I set them in the MP tray on envelope setting and printed 20 just to be sure, no wrinkles. So, at this point in time, I threw it back on sales and let them deal with it. Thank you for the input.
