Hello all, I have a T/A 3500i that I got back on a lease return and bought it out so I could keep it for a rental. The copy count is right at 60k but the doc feeder has almost a million on it. Any suggestions on what I should replace besides the normal stuff (feed and sep, pick up, etc.) ?
T/A 3500i doc feeder
Tags: None
Re: T/A 3500i doc feeder
Hello all, I have a T/A 3500i that I got back on a lease return and bought it out so I could keep it for a rental. The copy count is right at 60k but the doc feeder has almost a million on it. Any suggestions on what I should replace besides the normal stuff (feed and sep, pick up, etc.) ? -
If you are prepping it to go out I would change the Torque Limiter, it is the piece that the Pulley Separation (commonly called the retard roller) fits over. I have had those go out several times on high count DPs. It will cause an intermittent multi-feed of pages in DP. IMHOComment
