TA3500i background on scanned documents
  • B0265
    • Jan 2007
    • 718
    There is a background only when scanning, not visible when copying. Have cleaned the optics and calibrated with chart 1 in U411.
    CCD?
  • Intone
    • Apr 2015
    • 68
    Re: TA3500i background on scanned documents
    is the original on regular paper or colored paper? damaged in any way?
    • B0265
      • Jan 2007
      • 718
      Regular white paper.
      • Ctl-Alt-Del
        • Jul 2006
        • 430
        Any different scanning from the glass vs. Doc Feeder?
        • B0265
          • Jan 2007
          • 718
          No
          • tech28
            • Jun 2013
            • 434
            Are you scanning in color? Or B/W? Can make a difference.
              • 22979
              I'm thinking it must be a color scan, since the background has a reddish hue.
              If it were focus, it would appear worst at the trailing edge. Perhaps one of your mirrors is slightly loose/unfocused, or maybe it has a coating of something that doesn't come off with glass cleaner. Check each mirror to see if it rocks at either end, and re-clean the mirrors with 91% alcohol.
              I know this machine does not use fuser oil, but machines that did would get this affect from fuser oil vapor on the mirrors and lenses.
              It's got to be dirt or focus. That's it. =^..^=
              • Eresources
                • Nov 2011
                • 37
                Double check the little Black hard plastic square "pads" that the scanner mirror assembly slides on the rails with. I've had them disintegrate and cause some odd scanned images. Admittedly this would be in the copies too but maybe ones just worn down.
                • B0265
                  • Jan 2007
                  • 718
                  The strange thing is that you get the a coloured background even if you scan in B/W.
