C6600
  • Reeves
    • Apr 2012
    • 296
    [Error Code] C6600
    i have another kyocerea 4551ci with error code C6600 what could be the problem
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5017
    Re: C6600
    Fuser belt rotation error
    Check this link fot tips
    • sparkycivic
      • Apr 2017
      • 348
      Re: C6600
      fuser is probably piled-up or otherwise mechanically broken.
      • The_Murph
        • 96
        Re: C6600
        If the screws holding the fuser in place seem to be stripped out (typically on the machine front side), the fuser can flex slightly, causing belt rotation issues. The flex will change the rotation and potentially cause this error.
        If you phrase your inquiry properly, you will get the answers you seek...
        Good Luck ... You'll need it! HAHAHA!
        ~Big Dan~
