KM 5050I "adding toner"
  • jper34
    • Sep 2011
    • 225
    Hi folks,
    have a machine thats keeps saying adding toner, cust. is using "em" TK 717 toner, swapped acouple different cartridges to be sure. So I replaced belt drive, ans couple..I dont see anything obvious, machine does the clicking noise. I've it before on the KM 8580, I think, ut this is different set up.Heck, what am I missing...? at first , I thought it was a spring clutch, but not the case , here..please any help appreciated !..
    Thanks,
    Jaime,
    I.C.S.
    • 23010
    Re: KM 5050I "adding toner"
    Is it the right drive coupler? The only difference between the Falcon I/II toner and the Falcon III toner is a change in drive coupler. Other than the nomenclature they are indistinguishable. =^..^=
    • Santander
      • May 2009
      • 768
      Originally posted by jper34
      Hi folks,
      Thanks,
      Jaime,
      I.C.S.
      Have you run SIM 130 to adjust the toner level in the developer? If you have done this you may have a bad toner sensor in the DV unit which is not detecting the toner level. this is would be where I would start.
      • eddie110171
        • May 2012
        • 133
        Hello, 5050i was a unit created for Ikon and it had it's own special toner. A standard TK-717 will not work in it. The toner was only available through Ikon dealers. You can change the toner drive coupler and it will then run the standard toner and set the model destination to 2 for Kyocera or 66 for Copystar and you should be fine.
        • Geo
          • 662
          What everybody said ..mismatch between the drive coupler and cartridge , you need the correct cartridge... The clicking sound is a dead giveaway...
          Cheers..
          • jper34
            • Sep 2011
            • 225
            [QUOTE=Geo;578536]What everybody said ..mismatch between the drive coupler and cartridge , you need the correct cartridge... The clicking sound is a dead giveaway...
            Cheers..[/QUOTE
            Hi Folks,
            Thanks for the in put, I did replace the coupler gear,part# 302GR31010, along with the drive belt..the toner customer has is "oem" TK-717..which would the toner needed..does the 5050I series make the difference..? Is there a toner for this model other than TK-717 that I can try...?
            • eddie110171
              • May 2012
              • 133
              The correct toner is a TK-713
              • jper34
                • Sep 2011
                • 225
                Hi Guys,
                Thanks so much for all the help!!..as I mentioned, I did replace the drive belt and coupler gear, went back today with another(different) toner TK-717,I matched up the old coupler gear, just to see...when I arrived, I did go into service mode and change destination to "2" as advised, once I did that, copier is FIXED !!..Once again thanks !!
                now customer can just continue to use TK-717, which they had just purchased 2 new "oem" toners..so they are also happy !
                just wanted everyone to know the results...now I'm the hero in the eyes of the customer, only down side, I was hoping to sell them a re-rufurbed kyocera 3010I....
                Jaime
                Indep. Copier Svc.
                  • 23010
                  Congratulations on your success. =^..^=
