I have a potential new customer that wants to print prescriptions onto 5.5 x 8.5 paper. the problem is that the PDF that their medical application generates is a letter size document and it prints in the upper left hand corner of the page. it is not a full page print, it only prints on half the letter size page. I did manage to get it to work by setting the printer's left margin to about 2 inches with L3/L4 FRPO settings but that changes the margins for every print job. I have been tinkering around with Prescribe to move the margins "per print job" but can't seem to figure out prescribe. I went into the logical printer ports in the printer and set a start of job string to !R! RES; Unit C; SLM 10; Exit;I thought for sure that would work but it didn't seem to do anything. SLM is the command for set left margin. unit c is to designate centimeters. I also tried creating a text file with the same Prescribe commands and invoke it through the print driver's Prologue/Epilogue feature but that didn't do anything either. I even messed around with IC Link but with no luck. All i need to do is move the margins over to the right about 2 inches for their prescriptions to print correctly. I do have the Prescribe tech reference and command reference manuals but they do not show you how to apply the prescribe commands to the printer. Is there anyone out there that could guide me in the right direction?
