F20C error
  • MylonG
    • Jun 2025
    F20C error
    FS4200 with a F20C error-can't find anything in the manual about this error. Anyone seen this one?
    • 22999
    Re: F20C error
    From Service Bulletin C031-2LC-0057 Jan 2012:
    "An error is detected at the OS or some of the device drivers."
    You can interpret that however you like, but ... most CFxxx errors are print data errors. If you disconnect it from the network and the errors stop then most likely you've got wrong print data or non-print data hitting your printer's IP and it can't deal with it. Might be a wrong driver, might be some application that's hitting each IP on the network to collect data. Sometimes to can work around the problem by just changing the IP address of the printer. Naturally you'll have to change the IP at the drivers also: this is a great time to identify that Okidata or HP LJ5 print driver. =^..^=
    • MylonG
      Re: F20C error
      Reseating the additional memory took care of this one.
      Thanks,
