Kyocera 1135 4201 jams
  • JR2ALTA
    • Feb 2010
    • 2033
    Machine has many j-4201 (exit sensor not reached). I could never duplicate. After replacing feed rollers and drive pack client still complained. Finally they left it jammed and it was a sheet of paper under the drum just at fuser entrance but short of the fuser itself.
    I scraped off a lot of hardened toner from that area and ran a couple hundred but wondering if anyone has seen this out there.
    Thanks in advance.
  • D Colour
    • Oct 2008
    • 216
    Re: Kyocera 1135 4201 jams
    Have you had a look at this thread?
    ECOSYS M2535dn jamming
    Everything that has a beginning, has an end.....
    • taskalfa
      • Jun 2011
      • 97
      Thanks in advance.
      Check the Mylar guides under reg roller, I remove them altogether, they seem to work better without
