P3045DN
  • mansart
    • 855
    [Misc] P3045DN
  • sparkycivic
    • Apr 2017
    • 348
    Re: P3045DN
    Kyocera Net Viewer can be used to send those strings to the device.
    right click on the device listed in KMNV, go to "advanced", select "TCP/IP Send Data" and in there enter the commands in the Data field, with "Text" checkbox checked.
    or you can make a USB stick with the command in a text file that you "print" via the menu... I forget the details of arranging that off the top of my head as it's quitting time, I'll just recommend that you search on here, that subject has been covered before.
    • tmaged
      Owner/Service Manager
      • Oct 2008
      • 1890
      Re: P3045DN
      You can dump the command thru the ftp site of the printer.
      Hope that helps !
      -Tony
      www.dtios.com
      Become a fan on Facebook
      • darry1322
        • Oct 2010
        • 817
        Re: P3045DN
        Just a heads up ... you can also send them through KFS.
