By beef, I assume you mean beep. If the keys are beeping but nothing is happening. Try every key on pad and see if any are stuck down. I have had customers spill sticky liquid on the keypads and a button gets stuck down and the keys don't work. Press every key repeatedly and make sure it clicks and returns.
Any solution for the key pad of this is notworking but when press the key it beef
Can we repair this? Because when i swap to other its working,
If the control panel is working on another unit, it appears to be functional. Does a control panel from another unit work on the suspect unit? Does it just beep? If a control panel from a know working unit just beeps than you are looking at replacing the Main PWB.
When i replace new control panel its working,main pwb its ok, when you press its beeping, but the start button the green led light is off
