kyocera ecosys M2535dn
  • jewen25
    • Mar 2009
    • 197
    Any solution for the key pad of this is notworking but when press the key it beef
    Can we repair this? Because when i swap to other its working,
    ERROR HELP ME AND HELP YOU
  • eddie110171
    • May 2012
    • 133
    Re: kyocera ecosys M2535dn
    By beef, I assume you mean beep. If the keys are beeping but nothing is happening. Try every key on pad and see if any are stuck down. I have had customers spill sticky liquid on the keypads and a button gets stuck down and the keys don't work. Press every key repeatedly and make sure it clicks and returns.
    • Santander
      • May 2009
      • 768
      If the control panel is working on another unit, it appears to be functional. Does a control panel from another unit work on the suspect unit? Does it just beep? If a control panel from a know working unit just beeps than you are looking at replacing the Main PWB.
      • jewen25
        • Mar 2009
        • 197
        When i replace new control panel its working,main pwb its ok, when you press its beeping, but the start button the green led light is off
        • jewen25
          • Mar 2009
          • 197
          Thanks.i well try this
