Kyocera Ecosys M3540 Fax Memory Full
  • Ben Around
    • Apr 2012
    • 151
    My customer is getting a Fax memory full error on their Ecosys M3540 when trying to fax a 19 page document.
    I checked the scan settings, the resolution was set to 200x100.
    The default scan setting was set to color so i changed it to auto color/bw. But after changing it to auto color/BW is still gave a memory full error.
    The machine spec is 3.5MB of fax memory. Shouldn't that be enough to handle 19 pages?
    Would adding the optional 1GB of expanded memory (or the optional HDD) increase the available fax memory?
    Thanks for any help or comments.
  • Dsulli62
    • Feb 2021
    • 3
    Re: Kyocera Ecosys M3540 Fax Memory Full
    Did you ever find out how to free up memory> I have the same issue
      4 years and no response .. so my guess would be NO
        • 29603
        Any default setting changes required a reboot to take affect on KYOCERA machines and yes adding memory will also increase fax side.
        • spw
          • Mar 2015
          • 62
          Phil B..i see you troll on this site all the time with your bad attitude. Your cocky responses are not funny or clever. I rarely see you help anyone. If you are not going to be polite and helpful..i really don't know why you bother..
            • 8121
            Try a firmware update.
