Anti- Counterfeiting, Document protection
  • marks
    • May 2017
    • 3
    I have a Customer that is having issues with scanning (scan to folder) Checks and documents to folder ,
    Machine is a Taskalfa 3501i . When scanning Checks to folder the Machine displays a message to TURN OFF MACHINE AND TURN BACK ON
    without sending the scans to the folder.
    this customer has been scanning these materials in this machine since installation,but recently this issue has started occuring and Customer is becoming frustrated. any suggestions ,Ideas , or Solutions would be helpfull !
    Mark
  • ntbann
    • Jan 2012
    • 628
    Re: Anti- Counterfeiting, Document protection
    Scan check in B/W and enlarge the image some should work.
    • Geo
      • 662
      What "ntbann" said. This is a known and common "problem"
      Cheers.
        • 23009
        You might try downgrading the firmware a level or two. =^..^=
        • wragsdale
          • Jul 2014
          • 188
          Just for further insight into this type of counterfeit protection; It's called The EURion Constellation. Some implementations are quite sneaky, as seen in the USD$20 example on the wiki link.
