C2810
  • Reeves
    • Apr 2012
    • 296
    [Error Code] C2810
    i have a kyocera 4551ci with error code C2810 at first i tried to clean the waste toner box clean waste toner motor still the error code is still there.so i got another working machine i have replaced the following
    waste toner box
    waste toner motor
    transfer belt unit
    front PWB
    Engine PWB
    upgraded the machine to the latest firmware
    but the error code is still there.all the parts i replaced are working okey from the other machine and when i replaced the parts from the machine with error to the other working machines all the parts are working okey what could be the problem
  • wragsdale
    • Jul 2014
    • 188
    Re: C2810
    Do you hear any abnormal noise? Did you check the waste toner assembly/channel?
    The error code indicates that the motor is failing to drive. Since you have replaced it with a known working motor, it's likely that the gears and/or auger are binding up.
    • Reeves
      • Apr 2012
      • 296
      Re: C2810
      Thanks for your reply
      but when i take the parts to the other machine they are okey and the other parts to the some machine am still getting the error code
      • sparkycivic
        • Apr 2017
        • 348
        Re: C2810
        have the mechanical parts of the waste transfer augers from transfer belt to inner-unit been verified and cleaned?
        No mess on the back side of the yellow developer?
          Re: C2810
          did you vac out the waste lines before swapping any parts around? A lot of times the lines (channels) get clogged up and will cause motor failure errors on ALL brands of machines.
          I always do a thorough cleaning before replacing ANY parts... why waste time swapping parts? cleaning different areas affected can sometime reduce the need for part swapping .
          • Santander
            • May 2009
            • 768
            Re: C2810
            Agree with Wragsdale, the waste toner auger is probably binding up. Usually vacuuming out the channel while rotating the auger manually dislodges any caked up toner. Since the motor works in another unit it is most likely the auger or its drive gears keeping the motor from reaching its assigned speed because they are binding up.
            • Reeves
              • Apr 2012
              • 296
              Re: C2810
              before i swapped the parts i cleaned the parts after still was getting some errors thats when i swapped but even the parts from the working machine are give me the error code C2810
              • niyaskarimba
                • Sep 2014
                • 110
                Re: C2810
                Dear All,
                We are also facing the same issue.Kindly advice us the possible solutions.
                Thanks in advance
                Regards,
                Niyas
                  Re: C2810
                  Originally posted by niyaskarimba
                  Dear All,
                  Thanks in advance
                  Regards,
                  Niyas
                  Wow total lack of information here.
                  Lemme guess you are a newbie tech or the end user.
                  • ThisPete
                    Too old to care
                    • Jun 2014
                    • 214
                    Re: C2810
                    Dear All,
                    We are also facing the same issue. Kindly advice us the possible solutions.
                    Thanks in advance
                    Regards,
                    Niyas
