Low Memory Error on Printer
  • chuckles2666
    • Aug 2025
    [Misc] Low Memory Error on Printer
    I have a customer who is getting a low memory error on her Copystar CS 3011i MFP. They were originally having this error with a smaller machine. We then upgraded them to a bigger machine that had separate RAM for the FAX, double the RAM for the machine itself, and also an on board SSD. They are constantly scanning, faxing(receiving and sending), and printing. After we upgraded them, they were still having the problem. So we contacted Kyocera and they said to upgrade the firmware, which we then did, and that took care of most of the problems. Then they were getting low memory error on 1 page scans, but nothing else. We are at a standstill, on what could be causing it, and so is Kyocera. I am looking for any help to get my customer taken care of, they have been very understanding so far, but they are starting to get irate. Any help would be greatly appreciated.
    Sorry for the long winded explanation, but I figured the more information the better.
    Thank You Very Much
  • habik
    • 2013
    Re: Low Memory Error on Printer
    Have you tried changing IP address?
    Sent from my Mi A1 using Tapatalk
    Firmwares HERE
      • 23009
      Have you initialized the fax? =^..^=
      • copiertec
        • Jan 2016
        • 2211
        have you lowered the scanning to 200 x 200dpi or less and tried changing to black and white instead of auto or color scanning?
