km-2050 can't use scanner
  • cmpelser
    • Jan 2008
    • 173
    Hi, I just installed a KM-2050 with optional fax and scanner.
    I cant set the ip address for the scanner, when I select scanner settings in the menu it says " cannot use scanner" press ok.
    please help - brand new installation.
  • B0265
    • Jan 2007
    • 718
    You must connect the scanner NIC to the network to be able to make any settings.
    • termacadon
      IT goofball
      • 66
      Correct, it needs network connectivity. Cross over cable with your laptop or else flylead into network.
