CS 255
  • jsimmons487
    • Dec 2017
    • 9
    CS 255
    2017-12-06 085725.PDFWe have a Copystar CS255 and its printing fine except when you make copies. When making copies the page prints out all black, however sending a document to print from your computer the print is perfect its just scanning.
    We have almost 40G pages scanned and a total of 110,000 printed
  • shamgar1981
    • May 2012
    • 34
    Re: CS 255
    How does it scan to file?
    • jsimmons487
      • Dec 2017
      • 9
      Re: CS 255
      Never used scan to file, should I try that
      • B0265
        • Jan 2007
        • 718
        Re: CS 255
        Check the scanner lock lever at the rear left side.
        • jsimmons487
          • Dec 2017
          • 9
          Re: CS 255
          The scanner does move, it also lights up
            • 22999
            Re: CS 255
            It's very easy to lock the scanner. I've done it without even knowing I've done it. All you have to do is grab the machine at the left rear corner, to move it.
            What usually happens is that the scanner lock prevents the scanner from reaching the slit glass. It can still copy from the glass, but not through the DP.
            Check the scanner lock. =^..^=
            • jsimmons487
              • Dec 2017
              • 9
              Re: CS 255
              Ill do that first thing I get to the office
              • jsimmons487
                • Dec 2017
                • 9
                Re: CS 255
                I just checked and the scanner is unlocked2017-12-06 085725.PDF
                • B0265
                  • Jan 2007
                  • 718
                  Re: CS 255
                  Then it might be a defective main board.
                  • jsimmons487
                    • Dec 2017
                    • 9
                    Re: CS 255
                    I did scan from desktop and it looks the same as the copy scanned as copy from the copier
                    • jsimmons487
                      • Dec 2017
                      • 9
                      Re: CS 255
                      I'm just using the scan APP on my computer, as a PDF. It looks identical to the Copy made from the machine itself
                      • shamgar1981
                        • May 2012
                        • 34
                        Re: CS 255
                        all black then?
                        was that with the document feeder, the flat bed, or both? any difference when you copy via the flat bed or document feeder?
                        • jsimmons487
                          • Dec 2017
                          • 9
                          Re: CS 255
                          all black then?
                          Yes its all black and I tried from both the feeder and bed
                          • Geo
                            • 662
                            Re: CS 255
                            Perhaps this T.B. will help...
                              • 22999
                              Re: CS 255
                              That's stirs some old brain cells. We had a bunch of bad main PWB's on that series, and the symptom was black copies and/or C3200 codes. Let's see if I can locate details:
                              Found this: Transistor in the CCD drive circuit fails on the Main PWB. Replace main PWB (302K094131). Error C0180 appears on power up (serial number mismatch). Run sim U004 to restore serial number on main PWB. Re-enter network and addressbook data.
