FALCON ll
  • Franky Tan
    • Jul 2025
    FALCON ll
    Hello ! i have a problem regarding km 4035 show ' tyre mark ' beside on drum refresh to solve temporary , after a few days tyre mark come back again. A new drum had been replaced the tyre mark come again in a few day, any solution will appreciated.THANKYOU IS FIRMWARE CAN HELP WHAT IS THE VERSION ?
  • Jimbo1
    • Mar 2008
    • 845
    Change the Main Charger and if you see little spots on the copies before you do that then change the whole drum assembly.
    "Some days you get the bear, some days the bear gets you."
    Cdr. William Riker
    • knobby
      • Oct 2008
      • 75
      how old is the drum ?
      describe the 'tyre marks' could be transfer roller?
      • kyoceradude
        The Great Gazoo
        • Aug 2006
        • 442
        There is a firmware upgrade that changes the transfer voltage and on timing. What happens is the tfr roller gets dirty and then starts arching to the drum damaging the drum. If you change the drum without the latest firmware the drum will get damaged again. See page one for sample and firmware level.
        My mission here on Earth is to help all you Dum-Dums!
        • termacadon
          IT goofball
          • Oct 2008
          • 66
          Is the "tyre" mark on the drum when you open the machine?
          Could be the cleaning strip/dispersion plate above the drum.
          • knobby
            • Oct 2008
            • 75
            Well ?
            • fourl6
              • Nov 2008
              • 94
              we had some fairly dodge katun toner that got stuck on the drums and also caused light copies... are you using genuine toner?
              • mitatech
                • Oct 2008
                • 10
                Drum fail, or Adjustment variable resistors VR on Drum.
                • Franky Tan
                  thank to all solution ,i have refer to leader.
