km2560 program loading
  • adel_nathan
    • Jul 2011
    • 103
    [Dead] km2560 program loading
    hi every one
    i have problem in km2560 the screen shows
    " program loading " and stop
    i change hard disk - ram - boat chip
    but dosn't work
    please help
    thanks
  • Tonerkiller
    • Oct 2012
    • 668
    Re: km2560 program loading
    The last one that I had with this problem I fixed by putting in a new memory stick
    • darry1322
      • Oct 2010
      • 817
      Have you tried these suggestions ?
      http://www.copytechnet.com/forums/ky...71=#post584204
      • adel_nathan
        • Jul 2011
        • 103
        i need the softwaer which can i make by it upgrade
        • adel_nathan
          • Jul 2011
          • 103
          i get the firmware of KM3060
          but when i try to download it , the screen get black and the memory flashing over more than 30 minutes
          please help
          • Up to date Tech
            • Jan 2018
            • 31
            Try to disconnect the hard drive
            • adel_nathan
              • Jul 2011
              • 103
              then ??
              Do I download software while the HDD disconnecting ??
              • Up to date Tech
                • Jan 2018
                • 31
                Try to turn on the machine.
                • adel_nathan
                  • Jul 2011
                  • 103
                  the last situation is " i change the control panel and the machine warm up then complete loading program , thanks GOD and thank you all "
                  but , i have now error code " C6000"
                  by the way i was change a lot of things during fixing the last problem , like Main PCB , DC controller , .... and others {Engine PWB (EPWB) - Main PWB (MPWB) }
                  could you help me for fixing new problem ( C6000 )
                  thanks for support
                  • protec
                    • Feb 2005
                    • 25
                    Try a sim 163 reset.
