Kyocera 4500i PM message with 100k on machine
  • tech28
    • Jun 2013
    • 434
    Have one with the Preventive Maintenance message, machine has 100K, tried to reset to no avail, what am I missing? Strange problem. Any suggestions?
  • darry1322
    • Oct 2010
    • 817
    Re: Kyocera 4500i PM message with 100k on machine
    If it's "Time for Maintenance T", run MM906 and update the firmware.
    • tech28
      • Jun 2013
      • 434
      Thank You Darry1322.
        • 23008
        There is another possibility. If you've got the original firmware, it's possible that you're getting a message "Time For Maintenance" (not "Time For Maintenance T" which is a different thing).
        The "Time For Maintenance T" message is a fault of not setting the installation date at install. Simply setting a later installation date and doing a U906 Partial Reset will solve that condition.
        The "Time For Maintenance" message when no maintenance is due is a firmware image. In the initial firmware there was a Maintenance D condition that the Kyocera nixed at the last minute. It does not appear in U250 or U251 screens, but hides there in a deeper level of programming. Update the firmware and run the U906 Partial Reset to solve this message.
        • tech28
          • Jun 2013
          • 434
          Time For Maintenance Message (T) is what I have. Thanks again Blackcat,
          • tech28
            • Jun 2013
            • 434
            Question, how do you set a later installation date on machine?
              • 23008
              U278. =^..^=
              • tech28
                • Jun 2013
                • 434
                Thanks Blackcat4866,
                • Geo
                  • 662
                  Hi Blackcat
                  I curious...How and where did you learn about "Maintenance D" and that it was in "a deeper level of programming." ?
                    • 23008
                    The bug occurred in original firmware version 3.02. The fix is noted in the firmware bulletin for version 5.02.
                    It probably wasn't worded that way. That's just how I remembered it in my 2 remaining memory brain cells.
                    Upon checking the database, there was both a Maintenance D and a Maintenance E that got nixed.
                    • Geo
                      • 662
                      Hi Blackcat...
                      Out of curiosity I tried looking up and finding the bug..I checked 3.02...No joy..And 5.02 on kda does not exist (5.0/5.01/6.0)...Such is life...
                      However, very impressive that you were able to pick up this bug...
                      Cheers.
