FS-4000 Drum Charge roller issues
  • HmkPrinterTech
    • Sep 2008
    • 21
    Hallmark is having a rash of charge roller failures on the 4000 printers. I cannot get to KMAConnect to see if this is a known issue, or if there is a way to clean the roller to prevent black horizontal lines on all the printouts.
    Can someone please check and see if there is a known issue on these?
    Thanks! Jeff.
    • 23010
    I've got a couple dozen out in the field, and have not done anything to them. But maybe I'm just lucky.......
    • BrickPilot
      • Sep 2008
      • 41
      Yep
      I'm getting heaps on FS-3900's and FS-2000's with this. Not too many FS-4000's sold here, but same thing.
      On most I can clean the charge roller and problem is solved. Some get grit particles that if left damage this and/or the drum surface. Kyocera do have a tech note on this fault.
      Are these in warm dry and especially dusty conditions?
      • kyoceradude
        The Great Gazoo
        • Aug 2006
        • 442
        We have several hundred in the field and have to clean the rollers, in some cases after about 25k. We atribute it to cheaper paper. We use mild soap and water to clean (of course you take it out to do it and make sure its dry before reinstalling).
        My mission here on Earth is to help all you Dum-Dums!
        • HmkPrinterTech
          • Sep 2008
          • 21
          Originally posted by BrickPilot
          Yep
          Yes, most of these printers are in the Manufacturing plants where the cards are made. Very dusty conditions.
          Is it possible that you could send me the pdf on the tech note? or anything else pertaing to this problem?
          Also, you said you "clean" the charge roller. How/what do you clean it with?
          Thanks for all your help. Jeff.
          • HmkPrinterTech
            • Sep 2008
            • 21
            Sweet! I was hoping I could somehow clean it instead of just replacing the charge rollers.
            Mild soap and water? So I can go in the restroom onsite and use the handsoap to clean it?
            • BrickPilot
              • Sep 2008
              • 41
              The tech note I mentioned is probably less detailed than what has already been said (warm soapy water). This is fine in the workshop, but can be slow to dry and may even leave a film. In the field, for expediency I'll confess to using Spray n Wipe and clean cotton rag. It's very quick and doesn't seem to have had adverse effects I've noticed in the last couple of years of doing this. 6-10 charge units per hour and definitly don't use alcohol instead.
              • HmkPrinterTech
                • Sep 2008
                • 21
                Wow! Spray n Wipe. I think I'll use ocean fresh.
                Thanks agian! Jeff.
                • BrickPilot
                  • Sep 2008
                  • 41
                  Thanks agian! Jeff.
                  No wuckin forries
