TaskAlfa 2552ci Thickness
  • MaxValkyr
    • Jun 2025
    Hi everybody!
    How to change the thickness of the paper so that it passes more slowly through the fuser unit?
  • habik
    • 2013
    Re: TaskAlfa 2552ci Thickness
    Changing media type settings perhaps?
    Sent from portable device using fast cheapset!
    Firmwares HERE
    • sparkycivic
      • Apr 2017
      • 348
      this is accomplished by setting the media type(paper type) to be the same as the actual paper, or arbitrarily set it to "thick" or even "heavy". Experimentation might be necessary with this setting for unusually heavy print coverage.
      • FriendlyTech
        • Jan 2018
        • 30
        Should be able to change from main screen, there should be a button saying Paper settings. Select the tray and change the media type.
