Kyocera Taskalfa 4002i gives out light prints.
  • Arc Angel
    Junior Tech
    • Jul 2012
    • 65
    Hi guys,
    I installed this 4002i only five months ago, and now it's giving out light prints. We've tried changing the maintenance kit, but still no difference. Any suggestions?
    The secrete of staying young is to live honestly, eat slowly and lie about your age..... No man is so poor as to have nothing worth giving.
    Re: Kyocera Taskalfa 4002i gives out light prints.
    Originally posted by Arc Angel
    Hi guys,
    samples of prints?
    other than the kit what have you done?
    • JR2ALTA
      • Feb 2010
      • 2033
      Is EcoPrint on?
        • 30228
        Could be dirty mirrors inside the laser unit. What kind of office is in? Assuming you cleaned the optics?
        • Arc Angel
          Junior Tech
          • Jul 2012
          • 65
          That's the thing....whether we photocopy or print from a computer, the image is light. The office doesn't have air conditioning. Any other suggestions?
          • scottybbb
            • Dec 2010
            • 126
            I have had to replace a black developing unit on a 2 series color box that went bad. Was making light copies on half the page.
              • 30228
              If they smoke clean every mirror and slit glass in machine you my still have to remove cover and clean the polygon mirrors in the laser unit
              No A/C fresh paper?
              • JR2ALTA
                • Feb 2010
                • 2033
                No A/C fresh paper?
                Floridians still have that freedom?
                • giddyupngo
                  • Oct 2014
                  • 109
                  Dealing with the same thing, 4002i giving out light prints, different densities on internal prints within one hour. I did a forced toner add in U132 and it says the toner is empty, though it isn't. I think it is a toner clog, but I'm not sure how to get to it.
                  • Kyo fan
                    • Dec 2013
                    • 368
                    This is usually caused by the locking shaft (the grey plastic pin you push inside after inserting dev unit) on the dev unit. It can break inside and doesn't stay in lock position. In that case you need to replace the dev unit.
                    • giddyupngo
                      • Oct 2014
                      • 109
                      Thank you, I replaced the developer ultimately, because the toner sensor output value was -21, it wad stating "toner empty", and there was plenty of toner. The new developer brought the toner sensor output value back between 3 and 5, as it should be. However I am still getting fluctuating toner density on the page. It is in a "metal shop" environment, so maybe something is shorting? I have a high voltage board on order, but I would appreciate any advice!
                      Sent from my SM-G930R4 using Tapatalk
                      • giddyupngo
                        • Oct 2014
                        • 109
                        Just an update, the high voltage board didn't help. Customer was using a Microsoft print driver, so we are looking into drivers as the cause.
                        • monstercopier
                          • Jun 2019
                          • 60
                          I have a similar issue, replaced the Dev and Drum and still printing light. Anyone figure this out?
                          • KYO_OEM
                            • Aug 2011
                            • 715
                            At first we must find the reason, HV or laser
                            1. check if you get "good" image on drum and/ or belt
                            1. Enter 10871087/ U100/ set AC auto adjust to "OFF"
                            2. remove the MC
                            3. print out internal status page
                            4. check if you get full solid image without margins
                            a: still light image --> HV problem
                            b: "good" image --> problem is coming from laser
                            5. Don`t forget to switch back U100/ AC Auto Adj.
                            • spw
                              • Mar 2015
                              • 62
                              just a quick thought. When you installed the new MK did you transfer the the springs that go on the transfer roller on the door?
