CS 2050 Broke front pivot point Paper conveying unit
  • Arkynsaw
    • Oct 2017
    • 54
    I need to replace the paper conveying base on this oldie , seems that part is available but looks like many of the parts that have to be moved from the old to the new piece may break or be sticky back . Has anyone replaced this part ? Any thoughts before I proceed ? Is there maybe a part number for the entire assembly ? Maybe a bulletin relating to this problem ? Thanks In advance , Ark .
    • 23009
    Re: CS 2050 Broke front pivot point Paper conveying unit
    It's been a long time since I've done one of these. Be prepared to remove all the consumables and flop the machine over on it's side to gain access. That's about all I can remember ... except that it was unpleasant. =^..^=
    • Santander
      • May 2009
      • 768
      The actual removal of the conveying section is not that hard, there is a procedure in the manual for it. There is no part number for the entire assembly and you are correct that some parts [the conveying films] are attached with sheet glue, so you better order those as well, never had luck with peeling them off and re-attaching them, they deform too much. You will also need to be careful of the contact plate for the transfer roller as you can easily deform that on removal. Not an easy job, but it can be done in one and a half hours.
