FS 4300 Developer not installed
  • itchyfinger@att.net
    • Oct 2017
    • 77
    [Misc] FS 4300 Developer not installed
    IMG_1472.jpgIMG_1473.jpgIMG_1470.jpgHi guys,
    Pulled drum/dev unit out to clean charge roller. Put back in and says developer unit not installed. pulled it out again and found this contact spring in bottom on left side. Anyone know where it goes and possible send me a picture of how its in there? Both service and parts manual dot show it and tech support not much help at this time.
    itchyfinger
    • 22973
    Re: FS 4300 Developer not installed
    I suspect you'll find a home for it on the bottom of the drum unit, possibly developer bias. Sorry I don't have a machine handy to take a picture of. =^..^=
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5002
        • Oct 2017
        • 77
        Thanks for a picture that shows where t goes. not that is in place I still get DEVELOPER UNIT IS NOT INSTALLED. Thinking will put new drum and dev unit in it next. any other ideas befor I order this stuff? We don't have another unit to try stuff in and I don't see a reset such as 906 version in unit.
        • lees
          • Apr 2011
          • 95
          Check the pins on the connector where the developer connects to the drum on the left side of the drum. This is not the connector that you plug into the board, but there is a connector that the developer makes connection with on the drum as it is pushed in place. It has a black cover over it that pushes down as the developer is installed in the drum unit. We have seen these pins bent and distorted and cause all kinds of different messages on the printer.
            • Oct 2017
            • 77
            we installed another drum/developer unit out of another unit we got our hands on and same message. next stop going to order an engine board and try it. will let everyone know if it fixes it or not.
              • 22973
              That contact may have shorted something out on it's travels. =^..^=
