printing from Firefox
  • Scott
    • 196
    Have a school district that cant print using Firefox from any PC to any 01 and 02 series units. Anyone seen this or have any ideas??? Thanks in advance
    Scott
  • sparkycivic
    • Apr 2017
    • 348
    Re: printing from Firefox
    what happens when they try?
    • Scott
      • 196
      Sparky, it never shows up in the print queue, I haven't been to the location yet but this is what I'm being told
        • 23008
        Are they using a Kyocera KX print driver, printing to an IP address, static address on the MFP? Does it print from other applications? =^..^=
        • Scott
          • 196
          Yes it does print from all other applications
            • 30216
            Load latest kx print driver on a local workstation configure pdl to pcl5 and print. Also check machine printer is set pdl auto.
              • 30216
              Are you printing from windows or mac?
              • Santander
                • May 2009
                • 768
                Have you determined what they are trying to print with Firefox? Mozilla dropped support for Adobe flashplayer 6 or 8 months ago, so if the page they are trying to print contains info from flashplayer it will not print. The work around is to install a modified version of Firefox that Mozilla has put up on their website that essentially rolls back Firefox to a previous version, but remember to turnoff auto update in Firefox, otherwise it will be updated to the latest version and you have gained nothing. The roll-back version is difficult to find, I would suggest using the search function in the forums and look for Firefox Setup 52.0.1esr.exe. It worked for us. Also as others have said, make sure you are using the latest full version of the KX driver, the Universal KX driver does not handle web pages with embedded info very well.
                • KenB
                  Geek Extraordinaire
                  • Dec 2007
                  • 3944
                  Here’s a link to it: Mozilla Firefox Web Browser — Download Firefox Extended Support Release in your language — Mozilla
