Fs-c2526 color registration
  • mrfuser
    • 1624
  • sparkycivic
    • Apr 2017
    • 348
    Re: Fs-c2526 color registration
    I think the most-utilized answer to this particular problem with this particular engine is: throw it in the trash, put something (anything!) else in it's place.
    If you want to keep the customer, you will follow the recommendation given above.
    • tech28
      • Jun 2013
      • 434
      Have put out a couple of these series, great running machines, other than the toner yield. So.....far.
      • George J
        • 107
        Check bulletin Ref. No.2KW-0044 (D271)
        There is a special firmware that you need to load to reset the registration and keep it stable. Follow the steps in the bulletin and after about 30 min you should be done.
        • mrfuser
          • 1624
          • George J
            • 107
            You might want to check your pm's then.
            • Tonerkiller
              • Oct 2012
              • 668
              That's what it needs. Been there, done that.
              • D_L_P
                Self Employed
                • Oct 2009
                • 1196
                I'll second the recommendation to throw it away if you want to keep the,customer.
                Had 3 brand new c2626's in my territory. Worked fine for 6 months then they all needed color reg adjusted every week. Did the 'special' firmware which was actually like 3 firmware upgrades. Worked fine a few months, then back to color reg every week.
                Replaced the transfer belt even though it wasn't even 50% of its life. Worked fine a few months then back to color reg every week.
                I did that special firmware so many times on those and it might keep for a month.
                Only one of the three had over 100,000 on the meter after 3 years. Guess who didn't buy from us when the lease was up?
