KM5035 with C0100 then C6000 code
  • copyaction
    • Oct 2007
    • 985
    • 22999
    Re: KM5035 with C0100 then C6000 code
    I'm going to guess that the fuser and U163 are not going to fix your machine. C0100 indicates blown EEPROM #3 & #4. You're going to have a hard time getting EEPROMs for a FalconII unless you have a well stocked graveyard. =^..^=
    • copyaction
      • Oct 2007
      • 985
      I have a 3035 in the graveyard, would the EPROMS be compatible?
        • 22999
        I don't have a for-sure answer to that but this is what I suspect:
        I suspect all (4) EEPROMs are identical when new, but at the factory are written with a unique serial number, along with other data. You'll probably get a serial number conflict of some sort, and most likely have inaccurate counts. I don't think it will work.
        What I think needs to happen is, Kyocera needs to write the correct data to (2) new EEPROMs and send them to you. This probably would start with a call to the hotline.
        I'll be interested in hearing any other opinions. =^..^=
        • copyaction
          • Oct 2007
          • 985
          Thanks, I will bring the 3035 EPROMS and a fuser just in case since this is all I have at this point.
          I will let you know what happens
          • copyaction
            • Oct 2007
            • 985
              • 22999
              Congratulations on your success. Yes, the transfer bushings and springs are a common failure. =^..^=
