Copystar CS65501 gets stuck in processing
  • deserttech99
    • Jun 2013
    • 33
    When making copies, will run a set of 20 or so just fine, feed in another set of 20 and it will get through a few copies and then sit and drive for a long time, with the display saying "processing". Sometimes after several minutes it will then go into a jam, since it started to feed paper. Other times it will stay in "processing" for an hour or more until you shut it off and back on. Firmware is up-to-date but I am going to reflash it anyway. Couldn't find any bulletins pertaining to this. Ideas??
  • sparkycivic
    • Apr 2017
    • 348
    Re: Copystar CS65501 gets stuck in processing
    was it jam 010(x)?
    • darry1322
      • Oct 2010
      • 817
      Fuser unit. I tried adjusting fuser temps on the machine I had this problem with but in the end just replaced the fuser to resolve.
      • tmaged
        Owner/Service Manager
        • Oct 2008
        • 1874
        Fuser is the easiest to try. After that, I've had a couple of them run really slow until I replaced the HDD. I don't recall them showing a jam code though.
        Hope that helps !
        -Tony
        www.dtios.com
        Become a fan on Facebook
        • taskalfa
          • Jun 2011
          • 97
          I think it's basically waiting for the fused to get to correct temp, that's why it sits and then jams because fuser not reaching temp, it might be engine pcb, maybe try IH unit first
