ECOSYS M6530cdn slow printing
  • printlessguy
    • Sep 2015
    • 63
    [Misc] ECOSYS M6530cdn slow printing
    Hello All any thoughts or help would greatly be appreciated. a client of mine has an ECOSYS M6530cdn up untill a day or 3 ago no real issues other than user related. what happened now is copys, print jobs and internal jobs all print 1st page out normally and then 1 page every 6 seconds. and the machine is not set in quiet mode. it is using compatible's but was using them before. I dont remember the exact firmware but it was in 2015 i think
    am thinking of reseting the machine back to new and resetting it up again but.......
    andy
  • vsluggo
    • 23
    is it only printing or copying too?
    • printlessguy
      • Sep 2015
      • 63
      Re: ECOSYS M6530cdn slow printing
      Hi Vito its me Andy this is our issue
        • 23010
        My guess is that your toner density is getting further and further out of spec, due to the aftermarket toner. If you were to change the developing units you would see an immediate improvement. If you were to just install OEM toner now, it would gradually come back to normal ... maybe. =^..^=
        • printlessguy
          • Sep 2015
          • 63
          hmmm that is an interesting thought might have to try that
          thanks
          • JR2ALTA
            • Feb 2010
            • 2033
            I don't know if that model has fuser tabs for envelopes but worth a look. it will slow printing
            • GeneOR95
              • Feb 2018
              • 161
              Yeah, what he said.^^^ Kyoceras do NOT like aftermarket supplies.
              • printlessguy
                • Sep 2015
                • 63
                well updated the firmware. no change. found a spring under the printer found it goes in the pick roller assembly. and started working fine. not complaining but .....huh? wasn't jamming or mis feeding
