Taskalpha 3050ci Magenta shading
  • anzew
    • Nov 2014
    • 10
    Hi all,
    I am having an issue with this model here.
    Machine was showing magenta shades when printing multiple pages, first page usually came out clean.
    We replaced the magenta developer and drum at the same time, ran all calibrations and fault still happens.
    Checked all contacts were clean, I swapped over with another drum in the machine. Ran all calibrations again and machine is printing fine, however I have a feeling it will refault.
    Have a look at the sample prints, I am leaning towards a high voltage board.. Cheers
  • Tonerkiller
    • Oct 2012
    • 668
    Re: Taskalpha 3050ci Magenta shading
    Looks like bad dev and charge unit
      • 22999
      High Voltage Unit is a good candidate if it comes back. =^..^=
      • anzew
        • Nov 2014
        • 10
        Thanks for the info, the dev and drum have been changed with new units.
        • anzew
          • Nov 2014
          • 10
          Hi blackcat, would it be high voltage PWB1 or PWB2
            • 22999
            I think it's HV#2, the big one behind the main drive. =^..^=
            • pascalb.
              • Aug 2016
              • 47
              ello everyone
              I already had this problem.
              1st copy ok and the background goes up after several copies.
              This is the transfer belt
              do the 469 /464 calib /and 410 after change
              good luck.
              Do not lament,
              do not mock,
              do not hate,
              but understand.
