Kyocera 4501i dark background
  • kaborwen
    • Feb 2010
    • 146
    #16
    Re: Kyocera 4501i dark background
    Originally posted by JR2ALTA
    [ATTACH=CONFIG]38991[/ATTACH]
    I'm just a part time kyo tech so I hope someone seem this before.
    Looks like drum/ charge issue but no change whatsoever after replacing the dk6306 unit.
    I did vacuum out machine and cleaned contacts. Oem toner, current firmware. Only 230k on the machine
    I'm thinking next step high voltage board, any help appreciated.
    Hi,
    Is your toner an OEM cartridge ?
    If not, you have to replace DV unit.
    • patrickjlc
      • Feb 2015
      • 217
      #17
      Try another developer. I had that before, was a charge corona/drum
      Sent from my SM-G930V using Tapatalk
      • daveh12
        • Jul 2012
        • 157
        #18
        when replacing drum kits and dev unit just make sure to run the following U119, U930 to zero, U410, U412 and U464 to ensure a good image. U140 for dev units also.
        • JR2ALTA
          • Feb 2010
          • 2028
          #19
          I already posted the results. It was the dev unit. Before we took this customer their last dealer supplied genetic toner.
