M 3540idn
  • Hoosierdaddy
    • Oct 2016
    • 182
    M 3540idn
    I am in need of the part number of the LCD of this machine if someone could please help.
    Thanks,
    Hoosierdaddy
    • 23010
    Re: M 3540idn
    Not sure exactly what you want ... I'll show some options:
    Tablet only: 302NM94120
    LCD Display only: 302NM94110
    Tablet with LCD Display Assy: 302NM94060
    If your touch screen is unresponsive, won't calibrate, or activates the button up 10mm from the place you touch, then it's the tablet that you want. =^..^=
    • Hoosierdaddy
      • Oct 2016
      • 182
      Re: M 3540idn
      The Display is Black but machine is not dead. Probably the LCD only?
        • 23010
        Re: M 3540idn
        Possibly, or the op panel control board. Have you tried reseating connectors and ribbon cables? =^..^=
        • JR2ALTA
          • Feb 2010
          • 2033
          Re: M 3540idn
          I've had blank screen and replaced 302NM94061
            • 23010
            Re: M 3540idn
            302NM94080 PARTS PWB ASSY H PANEL MAIN SP
            Next logical choice, next up in price. =^..^=
